You may want to look at the Calibration for the Z axis steps per mm setting and adjust it if need be. Check out my reply in this thread. Also, check to make sure the connection between the motor shaft and coupling is tight.
Calibrating my X-carve 1000 - X-Carve - Inventables Community Forum
