(X-Carve 1000mm) Despite homing the machine, setting a zero point before each carve, and confirming my material thickness multiple times, making sure my material isn’t cupped or warped or bowed, making sure my bit is fully seated and the collet is tight, I still have issues with my bit not cutting some sections of the pattern on either the first pass or any subsequent passes either. Any suggestions?
Oh and side note, during my machine setup, I couldn’t get my z-probe setup to work. When I would would attach the clamp to the collet, the computer wouldn’t register it. (Not sure if that makes a difference or not)
Thanks,
David
