I have a Genmitsu 3018Pro with an upgraded Y-axis, Z-axis aluminum spindle assembly, and an upgraded spindle ( 24V Genmitsu CNC Brushless DC Motor Spindle Kit with Drive Board).
I set everything up and zeroed the X, Y, and Z axis’. I uploaded the Gcode file, and hit the “send”. Instead of raising up to move the spindle into position, it lowers (usually into the workpiece) and tries to drag the rotating spindle into position, destroying the workpiece or breaking the routing bit. This happens in both the Candle software and UGS software. Same when trying to use the “Safe Position” it thinks the safe position is into the workpiece instead of away from the workpiece.
It has been suggested that it may have to do with the dollar sign ($) codes
First, Does the Z jog the correct direction?
If not,
What’s your $3 value?
To reverse the Z, you must first determine the current $3 value. If it’s 0-3, add 4 to it. If it’s 4-7, subtract 4.
Yes, the Z jogs in the correct direction.
Also, the $3 value is at 0. So I should change that value to a 4?
Ummm, how do I do that? I am a quick learner, but am also a noob
Then your Z isn’t moving the wrong direction. No need to change your $3 value.
When you click “Safe Position” can you see what command is sent.
Does your machine have homing switches?
How are you generating gcode? Can you share the first 20 lines or so of the gcode that caused the crash?
Before we go further, let me make sure of something…is the Z+ button (Candle) used to move the spindle closer (down) to the workpiece, and the Z- for moving spindle away (up) from the workpiece?
No. I don’t use candle, but moving Z- should move the Z down and Z+ should move the Z up.
Thank you for clarifying that for me…that being the case, my Z-axis is reversed from how it should be.
I do not normally use Candle for running Gcodes, I use UGS. I know that in UGS, I can reverse the Z-axis through the setup wizard. It was a Sainsmart representative that had me reinstall Candle, so he could see what my ($) values were.
So, to answer your earlier questions, no, the Z-axis moves in the opposite direction, both when jogging, and clicking the “Safe Position” button moves the Z-axis down rather than up.
As far as “homing switches”, I am unsure what you mean. If you mean physical limit switches, then no, this machine does not have them.
Generating Gcode: I use Easel to create my Gcodes.
By the way, I really appreciate your help with this, I was becoming frustrated, and thought I had made some mistake when installing upgrades to my machine
Here are the $ values:
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=10000
$31=0
$32=0
$100=800.000
$101=800.000
$102=800.000
$110=1000.000
$111=1000.000
$112=600.000
$120=30.000
$121=30.000
$122=30.000
$130=200.000
$131=200.000
$132=200.000
Can you tell me where I can find what these values mean?
Wherever you can enter commands, type
$3=4
Thank you so much for this! It will be extremely helpful in configuring my machine. For the life of me, I couldn’t find these ($) value explanations anywhere (of course, I could have been searching for them in the wrong way).
This is a good site to bookmark too.
FGSLWoodworks-
I had the exact same thing on my 4040 and the support team sent this to me and that resolved the issue. I hope that it helps.
Thanks for contacting SainSmart! This is George from SainSmart support. I am sorry to hear about the issue you are having with your CNC. To start things off, let’s make sure that your CNC firmware is ok. Try homing your CNC in Candle, and then type $RST=$ into the command console and hit enter. This will reset your CNC firmware to factory default. Once you have done so, try jogging the X axis up or down, does it move in the correct direction?
If so, go into Candle’s settings and use the following probing code:
G91G21G38.2Z-80F200; G92 Z14.09; G0Z5M30
Don’t just copy and paste, though, change the bolded number to the thickness of your Z probe as accurately as you can measure. It should be around 12.35 but it is always best to check. With that code in place, try probing and see how it goes. If it works without issue, does the offline controller also probe normally now?
