I’m trying to run a carve with three circles set inside three hexagonal shapes.
Circle1/hexagon1 carve okay, but at about 75% of the depth I set the carve to.
Circle/hex 2 and 3 are carving way too shallow-- about 2 mm deep instead of 8mm.
When I look at the gcode, the Carvey thinks its work position is -.7mm when it is still clearly carving in the air above the material.
The work bed and the material I am carving are both level.
Any suggestions?
