My upgrade turn-around continues, I saw this on Openbuilds when I went to get new parts for my Z Axis and thought it was neat. I’ve got it wired to a relay that picks at the same time as the spindle, and I drilled/ tapped 2 screws on the bottom plate of the Z Axis to hold it up. I haven’t seen it on here before so I thought I would share.
Could you post a link to the light? Looks like a good choice. Thank you.
This is the type I use: https://www.amazon.co.uk/sourcingmap-90mm-White-Angel-Light/dp/B06W2JZB8R/ref=sr_1_6?ie=UTF8&qid=1519749224&sr=8-6&keywords=led+car+o+ring
JV
LED ring light, mainly used with headlights/cars. Also available in 70mm diameter IIRC.
