It took me a while to figure it out, this information will be in the calibration video I’m making.
In Easel, go to Machine->Advanced->Machine Inspector. Settings $100,
$101, and $102 are the x, y, and z steps/mm, respectively. Write
down their values. -
Calculate the new steps/mm using the equation in this picture (X axis
for my machine):
- In Machine Inspector, there’s an entry screen called “Console”. Enter the new setting like I did in this picture (again, X axis for my machine):
- Hit Enter, and then hit the refresh button over on the right of the settings section (double arrow).
- Verify the setting you changed is actually the new value.
- Close Machine Inspector and refresh Easel.
- Open Machine Inspector, and verify the setting is still what you want it to be.
You should try to make the calibration measurement again, and may have to tweak it a couple times for each axis until you’re happy. It took me 2-3 rounds of measuring and adjusting until I got my X and Y axis within .1mm over 500 mm, using a large scale. It took 4 rounds to get my Z axis within .0005" over 1" using a dial indicator.
I haven’t seen any documentation to explain any of this, so it’s all new to me too. I just figured it out 3 days ago. Hopefully my calibration video specific to Easel will help others out in the future.
Let me know if you have any more questions. I can’t promise any answers, but I’ll let you know if there’s anything I can do.
Rob
