My z axis will not touch the material. I use the z probe and set everything up fine. When i hit carve it goes and just “Carves” in air because it does not lower to the material. Also sometimes when hit carve the machine takes off and goes to the top right of the waste board and crashes if i do not hit E-stop fast enough! Please help me!
Maybe the Z motor is configured in reverse? check the wiring (black and green maybe are inverted)
Sounds like you didn’t set your Work Zero.
