Z Axis wobbles
Is it normal for the Z Axis to wobble if I move it with my hands?
I am afraid its giving my cuts a certain margin of error.
I believe its the drive rod and the bottom of the spindle mount.
I own a 1000x1000mm carve with ACME rod and 24DV Spindle.
Thanks in advance for dealing with my concern,
-AD
Make sure your eccentric nuts are tight on your adjustable v-wheels. You should not be able to wobble the z-axis side to side.
Thanks!
This seemed to have solved the issue.
I might have tighten them enough to see a shave of metal come out, but the loosening the nut I found it locked the wobble effect.
Thanks once again!
