What do you call the plug that the z-probe kit uses to connect the probe to the xcarve? I’m looking at making a digitizing probe and want to just use that connector that’s already there.
Thanks!
Larry, do you know the connector part alone, not just the cable assembly? I would rather not take the chain drag apart to replace the whole cable assembly. I can easily solder in a new connector. Thanks.
or will any DC Barrel Jack 5.5mm x 2.1mm bulkhead connector work?
Those are the ones I was looking at. Thank you Seth. Much appreciated.
