Sometimes the Z-probe cannot be set up, because the easel software does not give me the option to attach, it just asks to lower the bit tip to the material surface manually.
It worked before, but disappeared.
Anything I overlooked?
Mine caused me some confusion recently in this very way and it was because it was partly unplugged from the brass “puck.”
There is something else I am afraid since the option what Easel usually shows to plug in the Z-probe does not even appear.
You also need to enable probing maybe it was shut off.
I’ve noticed the same thing is happening to me. I used to have the option to set up the probe but that’s not an option presented to me any more. Weird.
