Can I change the thickness of my Z probe? The one from Inventables measures .587", If I have one that measures 1.0", can I change that in the settings?
Thank You
Russell
Are you using Easel to control the machine, @RussellCrawford?
If yes, see Phil’s answer below.
@RussellCrawford Yes you can. Go back to the machine setting up. Go through the steps and when you get to the probe it will ask you if you want to change settings or advanced. I can’t remember the exact question but it opens a window to change all the settings including the probe thickness.
Awesome, thanks Phillip and Neil. I think we are going to get lucky again Phillip, Sally is headed East towards Mississippi.
I’m still using Easel. I purchased V-Carve and PicSender just need to install PicSender and figure it out.
I’m using UGS and VCarve. Yes, I think you are right. Going East is good. Cat 2 sucks though for Mississippi
