Z probe setup sequence fails
When setting up my z probe in Easel, the software takes me through the entire process and fails to start the “test probe sequence”. When running a job, homing and all jogs work properly then when setting up the probe, the program shows the spindle moving down however the actual spindle doesn’t move. I have checked the wiring “twice” and confirmed that this is an Easel issue, as the probe sequence in Openbuilds works properly. I have reloaded Easel local and the CH340driver. The port is correct. Below are the Gcode settings. Can you help me figure this one out?
$0=10
$1=255
$2=0
$3=0
$4=0
$5=0
$6=0
$10=115
$11=0.010
$12=0.002
$13=0
$20=1
$21=1
$22=1
$23=3
$24=25.000
$25=1000.000
$26=250
$27=3.000
$30=10000
$31=0
$32=0
$100=80.000
$101=80.000
$102=1600.000
$110=2000.000
$111=2000.000
$112=500.000
$120=300.000
$121=300.000
$122=30.000
$130=380.000
$131=380.000
$132=50.000
