Zbrush to Carvey
Hi, I’m a Zbrush 3d modeler with no experience with cnc. All the carvings, I’ve seen, created from Carvey seem 2d. Is it even possible to create 3d carvings from Carvey and are there any tutorials?
Sure just export as a stl and then use Meshcam, there are a lot of tutorials on there site. here is a link of one i did.
I also use Zbrush.
You just have to create your object in ZB then do as suggested export it to an STL file.
on the other hand if your tool accepts grey scale graphics you can go into ZB and make the background completely black then use a flat shader and do a alpha grab and you get the grey scale info and that will work in Vcarve etc.
