Zero clearance insert - cutting to dimension
Hello,
I am looking to make zero clearance inserts and looking at cutting the piece to dimension to get an exact fit.
If my saw opening is 2 inches in a circle, do I set my cut setting to be 2 inches and “cut outside the line” ?
I am using a 1/8 inch upcut bit.
Please advise,
thanks,
Martin
Yes. Do a trial it and test the fit. Adjust the 2 inch either bigger or smaller as needed to make a perfect fit. Calibration is usually off slightly. On my machine I usually have to make my hole size about .003 smaller. Every cnc will be different. I not willing to try to get that small amount of error out of the machine. That level of tolerance works for what I’m doing
You might want to read yourself up on v-carve inlay :slight_smile:
