1/4 V bit 60 and 90 degree technical details
Hello!
I’m working on some countersink holes in Fusion 360 and am thinking that I can use the 1/4 v bit for this. Can anyone point me in the right direction as to where I can get the technical details of the bits so I can enter them into Fusion for generating an accurate toolpath?
Thanks!
This will vary per manufacturer.
The best way to do it is to measure the bit itself with a caliper or just use the ideal angles and cutting lengths specified for the bit and math it out.
That’s actually what I ended up doing. I used a caliper and measured out the bit and entered it manually. I was looking for more precise measurements from the manufacturer
It would be good to know which manufacturer inventables uses for their 1/4" v bits.
