My new X-Carve should be here soon. The waste board is plain but I have manage to get hold of the SVG file & imported it into Easel.
I am having a memory block, being really stupid or both but…Once the machine is built & calibrated, I want to use it to carve the waste board graphics. does it matter where I position it on Easel?
I’ve also built my own cabinet, what do you think? It’s nothing glamorous but it will do, plenty of draw space, cupboards for tools/extraction & pull out keyboard tray.
Hi there!
You cabinet and workshop looks very fine!
However, do nor forget to have a system with a vacuum cleaner (or bigger) to remove all the milling chips and dust, because there will be a LOT…
Regarding the placement I usually have the zero point in the lower left corner and the placing the milling piece some mm up and right. Just look so you have enough of material. I have experienced some problems with my internet connection as I use easel. If you lose the connection for jst a fraction of a second everything id ruined. Ensure a good internet connection and a good USB cable as well.
