1000mm XC step 5
At the end of this step it says to skip connecting the Y axis together if you have 1000mm kit. Is this correct, does this happen somewhere else?
"5. Connect End Plates with Extrusions
This step is for 500mm X-Carves ONLY; please skip this step if you ordered the 1000mm rail kit."
thanks Angus
Yes, I didn’t notice this and couldn’t figure out later why according to the directions I was short 2 rails. It seems somewhat cringe worthy to have the y-rails flopping around without something to sit on during the build process, and if you skipped that little notice like I did, I just unbolted them later to attach them to the underside of the wasteboard. Actually made working slightly easier as it was simpler to handle on the table.
