Hi,
Unfortunately the time has come to sell my xcarve. Due to a growing family, lack of space and no spare time it has to go.
Ive made many successful projects on the machine and its been great to use.
It is the 1000mm xcarve with x controller and dewault router with 1/4 inch collet and 1/8 inch precision collet, z probe, the xcarve dust collection system, assembly tools, xcarves router bit set, over £500 of top quality router bits (listed below) also included is a festool router bit systainer, a very accurate mini engineers square for fine calibration. The xcarve also comes in a custom enclosure with 3 drawers, a space for an extractor, polycarbonate viewing panel, hinged front face, is built on heavy duty braked roller wheels and has internal tridonic led lighting and laptop stand
Router bits
Diamond tipped spring loaded engraving bit
Spiral O Single flute for aluminium 1/4 shank 1/8 tip
Spektra coated Spiral O Single flute for plastic ¼ shank 1/8 tip
Solid carbide up cut 1/16 ball nose ¼ shank, 3 inches long
Solid carbide double up cut ball nose spiral 1/8 radius ¼ shank ¼ tip
Solid carbide engraving 30 degree 0.005 inch tip 2-1/4 inch long ¼ shank
Spiral o flute, for plastic 1/8 tip ¼ shank
Upcut 4 flute spiral bullnose ¼ tip ¼ shank 3 inch long
Carbide tipped straight plunge ½ tip ¼ shank
Solid carbide 18 degree single flute engraving ¼ shank
Solid carbide compression spiral ¼ shank, ¼ tip 2-1/2 inch long
Solid carbide 30 degree engraving 0.040 tip ¼ shank
Solid carbide spiral plunge 2 flute upcut ¼ tip ¼ shank
Carbide tipped v groove 90 degree ½ inch tip ¼ shank
Solid carbide straight plunge 1/8 tip ¼ shank
Ingroove insert engraving tool body with blade ¼ inch shank
Tapered angle 5.4 degree bullnose ¼ inch shank
Located in Kent, about 15 minutes drive from Junction 6 of the M25
The wheeled unit can be separated into two, collection would need to be in a van or large 4x4
£2000 or open to offers, cash on collection
