Lower current = less loss in the wire = less voltage drop at the machine
Lower current = smaller wire size for a given run length = less money
Lower current = less heat build up in the motors = longer life
Yes.
I believe that 220 also helps with motor startup, increasing brush life. (Don’t quote me!)
I^2*R = heat. Double the voltage, half the current. Less heat = longer life
