3 Layer project
This one is driving nuts. this has a rough and detail cut. I set the bit at 0,0 and probe. The spindle starts and starts a hole to the right raises then goes off the work piece and is carving air.
My first question is this Ben’s Digger or Bens’ Digger? I am not seeing any additional drill holes or anything odd in the code. Can you verify all your belts are tight?
