Fast question…
Are 3D files resolution dependent?
Thanks in advance,
Guy
Fast question…
Thanks in advance,
Guy
No 3d files are not. However they are specific sizes and you can scale them up and down.
The resolution is based on the polygons. The higher count usually the higher resolution.
if your using Aspire/Vcarve then you can import STL files The same type that 3d printers use.
Great. Thanks for the detailed answer.
Best,
Guy
