Hi I had a 3d carve I was working with ,went to generate the tool paths was using 1/4 in endmill for the roughing and 1/16 for the finish , it would go and start the tool path then just went away , said there was a error , I change the bit to 1/8 and it worked , it won’t let use the smaller bit as there is to many lines , can I just place the 1/16 bit and have it show the 1/8 and still carve it
