On the finishing cut only, my machine is cutting on the purple line. Any idea why
You have set your cut type to “Rectangle Relief”
The default cut depth of “Rectangle Relief” is the full depth of the material.
If you do not want it to cut to that full depth than you need to edit the “cut depth” setting under the “Cut Style” settings.
Once again thankyou, how do you get to be a genius, all I can do is repair vintage furniture
Dave
