This is my third generation dust shoe.
Gary,
This looks sweet! How does it attach? It looks like there are magnets in the sides, and although I can tell you have acrylic on the bottom of the Z axis, can’t tell how the rest of it works.
–Rick
It magnetically attaches to arms that are inserted in the T-Track.
Nice
Brush comes from McMaster-Carr. Luckily there’s a warehouse 20 mins from me. I can place an order & pick up items w/in an hour or so!!!
Damn. Totally jelly!
Not only shoe, everything I see is the perfection. Great job Gary.
something new coming!
Any tips for cutting acrylic? I’m getting melting (and a mess) with my Dewalt 611 even at the lowest setting. Thanks!
Single Flute Up-cut bit - Slowest RPM - shallower depth of cut - Fast enough feed-rate to leave area quicker before start heating up…
At 16k rpm plastics are difficult media to master but most acrylic are extruded and have a lower melting point than cast actrylic. You need to go faster/shallower and/or add some sort of means to keep things cool.
Cast acrylic is more expensive also which makes most generic types of acrylics of the extruded kind.
I was successful cutting at 17k rpm, DOC=.02, FR @110 ipm. w/good vacuum. Dual flute upcut. I was a lil scared @ 1st, but it worked, no melting!!!
Do you want to Share it to other X-Carve Users?
Yes, please share the design if you’re willing? Thanks, looks awesome, Gary
The design is fairly simple to make, especially if u have any simple illustrator skills. Hell,I did it!!! I was always told that if you can read a tape measure then you can build anything. Great job BF!!!
Rockler
