I Purchased the 500w spindle with 220v power supply with speed governor my question is cam the Xcontroler be safely be operated with 220v US power and can both the Xcontroler an the spindle power supply be powered by the same power cable. and do you have to put a 220v power cord on the Xcontroler. thanks i need help hooking it up to my Xcarve . Harley
i can answer part of your multipart question…
YES, the X controller can be run on 220v… there is a selector switch on the power supply and you can select 110 or 220 during assembly
Thank you Robert i Apppreciate your reply that helps Harley
