750mm x 500mm upgraded xcarve
This is an upgraded x-carve with a custom size of 750mm by 500mm it fit my needs at the moment. Upgraded to a cnc4newbie Z axis, 9mm belts and TBDCNC risers. I bought misumi extrusions that still need to be drilled out and installed but everything else is done. Works as it should. Comes with lots of bits and extras like a quiet Fein turbo shop vac dust deputy and relay for spindle. Everything in the picture expect the table. Willing to deliver to the trI state area but you have to be sure you’re buying it.
What is the asking price and where are you located?
$1200 an de I’m located in Brooklyn NY.
