I have attached the file in question. I am new to using Vcarve. So i made this sign. Im trying to get the letters on top and the image on the bottom. i did weld the name to the image, but in the preview when i setup the pockets, it deletes the name on the top. is it just a preview problem ?
Calculate and preview the toolpath for the vector with the name. See if that brings it up in your preview. Typically he only image the shows up automatically is a 3D model. You have to run he “preview toolpath” to have it show up.
You have the letters cut at a depth of .1 and the center portion cut at a depth of .2 so the center section just cuts right over the letters. You need to be aware of how deep each section is being cut and understand all the depth of cuts are measured from the top of the material.
If your background image is removing the top .2 of the material then it will completely remove the letters that are only .1 deep. You are either going to need to cut the letters deeper or allow the letters to stand over the background image,
Hey Allen, Thats what i want to do, is allow the letters to stand over the background image. instruction tell me i need to weld my letters to the bottom image then i set my pockets cuts but this is how i end up.
So you need to create a toolpath that is going to cut the background and leave the letters standing proud above background.
The way to do that is to have each letter as a closed vector within the boundaries of the background vector. then when you select the background vector and perform a pocket toolpath it will cut everything within the background vector down to the depth you provide, leaving the letters uncut since each letter is a closed vector.
Saying the same thing that @allenmassey said: Make a profile cut around your letters and save that toolpath. Then create the pocket cut for the remainder. The software will ignore the letters and cut the remainder. Then a profile around the object to cut it out. You can merge all 3 toolpath into one but I would keep the cutout profile seperat so you know that one will cut last.
