I have a 24 cm board that will s 27 mm thickI need to make a straight line cut that goes from a starting point of 19 mm to an ending point of 21 mm for a distance of 22 cm long. Is there any way to do this in easel?
Are the starting and ending points you listed (19mm&21mm) depths? I’m not sure im following what you’re explaining
If those are depths, no easel cannot do fluting like that. You can use multiple lines to achieve incremental stepdowns, but if you want a constant depth slope, fusion360 might be more appropriate.
