I got my x-carve this month and its probably the best thing I’ve ever purchased (and assembled) in my life.
I’ve been destroying a lot of stuff lately but have learned a lot from the forum posts (and experiments).
I was looking for some information about using a diamond drag on a clear acrylic piece (for edge lit signs) and then thought if its possible to engrave a photo somehow. I can’t afford buying photovcarve (is it?) right now. And I’m too new to CNC machining to understand G-Code (image2gcode) stuff.
Having some knowledge about graphic design, I managed to devise a super sad method. It takes too much time to calculate the toolpath and I think I am trying to do something very simple extremely inefficiently,
I would click on the carve button if you guys say the workflow seems fine and I might get some good results.
I did. But I thought it was for 3D carves. What I’m trying to do is barely scratch the surface of the clear acrylic using the diamond drag. Here’s a picture of what I got. It took about 10 minutes to generate the toolpath (probably my slow surface pro 3 at fault here). And it took about 4 hours to carve a 4x6.
I wanna do something similar more efficiently if possible.
