A subforum for cut settings
There should be a forum specifically for discussion of cut settings. Different materials, especially ones not in the Easel database, will require different feed rates, different depths per pass, and so on. For instance: The recommended aluminum setting didn’t work out for me, as I was cutting an aluminum bar 3.4 mm thick. I broke 2 bits before I changed the depth setting to 1mm.
there are charts out there with ballpark figures.
Sharing settings any further than than is useless since every machine is different.
