Tip first: If you select a 60 deg V bit as roughing tool for a bowl, but use a bowl bit instead, you wind up with very smooth sloped bowl sides and a nice curved transition to the bottom of the bowl.
Request: Not sure if this is my lack of knowledge or something that is not available in Easel.
It is easy to draw a curve using X & Y axis, I would like to be able to create curves using th Z axis for carving things like spoons and bowls or even for putting a wavy surface as the field of a sign that has raised letters. Is there a simple way to do this?
