Is there a way of making the grid say 1cm instead of 5cm? or scaling dimensions? So say draw a 47mm circle as opposed to a vaguely 46-49mm circle? - Easel Pro
Are asking about the background grid to Easel? You can make a circle and make it the size you want, then tell it to fill, cut on inside, outside or on the shape.
If you enlarge your drawing window, + and - sign lower right corner, the grid changes to smaller squares. I had the same problem earlier. Hope it works.
