y’all probably saw these on fb. may i ask again what bit was used on these and was a 1/4" acrylic used as well?
thank you.
thank you.
I believe they are laser cut. I personally use a 30 degree solid carbide engraving v-bit with a 0.1mm tip and 0.25mm doc. Works well enough but you can get better results with a laser in my opinion.
Nice stuff. just to note, the S on Superman’s chest is backwards in the photo.
I imagine whoever made it flipped the image (as you would to engrave the back) and forgot about his S
where can you get the files to do stuff like this? i want to use my xcarve to make these but i can’t find them anywhere… idk if they are dxf formats or what… just looking for some sources…
