How do you add a drag bit to the tool box?
it would be entered as a Vbit and you’d need to adjust the depth per pass and design depth based on the spring tension of the specific drag bit in question and material in use to obtain the desired pressure.
SethCNC how to do keep the spindle from rotating? Can it be set to zero speed or do you need to unplug it? I have an X-Carve Pro.
Op asked in easel topic so i was unaware the machine is a xcarve pro. But since they hid the vfd inside the control box, so you cant simply turn it off, yeah youd need to unplug the spindle cable…
