I have a lot projects that are made up of several, sometimes more than 1,000, individual SVG images. I need a way to select all the SVG files and adjust their depth of cut relatively. ie…increase or decease the depth of EVERY cut by the same amount. Is there a way to do this?
Thank you!
David
Currently, there is no way to do exactly what you want to do as far as I know. One thing you can do is to select one object, right-click on the selected object, choose the “Select by Matching Depth” option, and then change the depth. This will change all of the items selected.
If you only have a few depths to work with then this will go fairly quickly, but if you have 50 depths to work with then it will just take a little longer.
{:0)
Brandon Parker
