So I wanted to share a case study that I am working on with MDF cutting
Here are the details
Material: .22" MDF Eucalyptus based (not pine fiber mdf)
Tool: Onsrud 57-266 3/16" 2-flute downcut wood rout
Recommended Chip Load for x1 Dia: .006-.008"
Non-Changable Parameters:
Tool Diameter 3/16"
MDF Material
.22" DOC
Downcut tools only
Machine Used :
CNCRP PRO4896
2.2KW GMT Air Cooled Spindle 8000-24000rpm
No Vacuum Table
MDF Spoilboard only
Material Attachment Method:
18ga pin nails down each side of the sheet in the y-axis direction
Part Details:
Monogram Names varies (lettering)
Part Holding strategy:
Triangular tabs used .3" width and .055" height at programmers description
Objective of Case study:
Increase Tool Life
Minimize breakage of thin Script fonts
Improve cycle time
Minimize Chatter
So I have been working on this for awhile and want to share some recent discoverys that some people might not be aware of. That being that MDF will produce a “chip” when cutting if your using the proper tools
Why do we want “chip formation” when cutting really any material? Because its all about tool life and minimizing heat build up at the tool. If you are running your tools properly you will save money on expensive carbide
I am running a relatively low horsepower machine and spindle and not the most rigid set-up compared to more industrial like production machine. So I am very rarely able to achieve the proper chipload for a given tool. Some work-arounds are running your spindle at lower speeds but that requires more spindle horsepower so that might not always be the best option. Another option is to reduce your depth of cut and take more passes but this can cause a substantial increase in cycle times.
So we must look elsewhere for solutions to our problems and one possible solution will reside in the the proper tool selection for you application
We have a couple options on tools to evaluate
- 2-flute downcut wood rout
- 2-flute downcut chipbreaker
- 1-flute o-flute downcut spiral
- 1-flute compression spiral
2-Flute Downcut Wood Rout tool:
This tool has been my go to tool for quite some time now but I find that I am only able to get between 5-8 sheets life span. This is due to the fact that I am not able to run this tool at the proper chipload but I can get close as you will see in the picture on how we start to see chip formation and not dust
2-Flute Downcut Chipbreaker
These tools are great for low horsepower machines but I decided against this due for a number of reasons including material, part geometry, surface finish, cycle time, tool change
1-Flute O-Flute Downcut spiral
These tools are a great option for low horsepower machine because of how the tool geometry cuts into the machine. Also single flute tools are capable of achieving a higher chipload at a slower feedrate. These tools are commonly used in hard plastic cutting but will produce a superior surface finish in composite woods
1-Flute Compression Spiral
With the benefits of the above tool this tool has one disadvantage on thin .22" mdf and that is the length of the upcut section and the tendency for it to lift the material from the spoilboard due to our work holding strategy. Now I am experimenting with a 3/8" diameter in 1" thick mdf next as I will be able to get a mortise compression tool and achieve the proper chipload on my low horse power machine
So now that we have evaluated some tool options lets see some results with specifically the 2-Flute Downcut Wood Rout
Photo 1
Is showing the typical dust that is formed when typically cutting mdf without the proper tool chipload. This will introduce excessive heat into the tool and shorten tool life. Although the dust created does help with part holding
Here where my settings on these chips:
18000rpm
150ipm
.22" DOC
130ipm 3 degree linear ramp
.0042" chipload
Photo 2
Is showing that we are starting to get actual chip formation from the mdf material. This is good that means that we are getting closer to removing that heat and preserving tool life. Also we get the added advantage of shortening cycle time. However there are 2 disadvantages 1 being decrease part holding and minor increase in chatter due to the thin material
16200rpm
220ipm
.22" DOC
160ipm 3 degree linear ramp
.0069" chipload
Photo 3
Is showing that chips are not getting compacted in the cut path when running the tools at a higher chipload there are almost completely evacuate via dust collection
Just thought I would share my findings here let me know if you have any questions
