Trying to replicate the engraving in the wood plaque image. Ive tried all features on Easel and just cant get the right design.
Any tips/advice?
Any tips/advice?
If you are strictly using easel then best bet is to use image trace get it as close to perfect as you can then go into the image and edit the points as needed. Id probably remove the stars and make your own they will come out better that way. Same goes for the letters and numbers. It may not be perfect but should get you pretty dang close. Ive done that with a few American flags with different emblems on top and they come out great. Good luck
