I just recently got my X-Carve setup and have made a few cuts with it. What I have noticed is that the actual cut that is being performed doesnt fully align with the location that shows on Easel. While not a huge concern for a project like the one I am posting from scrap wood, it will be concerning if I am trying to align on a finished (or nearly finished) piece of work.
This is what I am seeing on Easel:
As you can see, the cut is nearly centered on the piece of wood.
When I cut though, it seems to cut a little high as seen below:
The dimensions are accurate in Easel when I set all of the sizes. When I set the X,Y at the beginning of the project, I put it in the bottom left corner (right above the corner) as accurate as I can get it.
I could understand it being off a little bit based off of where I set X,Y but it seems to be off a bit more than I am comfortable with.
Has anyone else experienced this?
Thanks!
