Hello everyone,
I am fairly new to the X-carve and im trying to cut some aluminum projects. I attempted cutting a project on an old street sign i had lying around and I had the feed rate at around 40in/min plunge rate at 3 and depth per pass at .1in(not sure if this was good). For the most part it cut pretty decent and only required a little clean up. After this trial i went to purchase a sheet of 16 gauge aluminum 3003 gr. And i am having major problems with the material gumming up while cutting. I’ve tested a few different speeds with spindle and feed rate, even bought a couple of 1/4" single flute bits and have yet to find the right settings. i would greatly appreciate any suggestions on where i may be messing up.
Thank you
