I’ve been looking all day for a replacement F608ZZ bearing (30169-01) here in Quebec, Canada. For some reason this specific bearing seems impossible to find, even from the local SKF distributor.
Ordering one from inventables is my plan C, since shipping would be more expensive than the item. Plan B is to get it from aliexpress, but shipping would be quite slow and in the meantime my Z axis is too imprecise to do anything serious. Any idea for a real plan A?
The bearing can now go right up. (and also down because the holding screws don’t reach it anymore)
I might be able to add washers to those holder screws, but those wouldn’t stop the bearing from spining across the axis formed by the two screw heads.
Also on the top :
The pulley is pretty much right there. Would be hard to find a washer that’s just large enough to provide holding, but not too large that it interferes with the pulley. (Quick look on McMaster : they either barely touch the bearing, or interfere.)
@NealRobinson : Yeah like I said that’s my plan B. Thing is, I’m using the x-carve as a tool for my job, so every day I wait makes me sadder.
@WillAdams : Two things.
First, the jam nuts were a way of securing the rod against the flanged bearing (the jam nut design used a flanged bearing too). That flanged bearing held like it does now, so adding the jam nuts doesn’t solve the issue. You still have a rod-and-bearing assembly flapping in the air.
Also, and that’s some quirky stuff, take a look at the acme lead screw. That second diameter where the pulley sits? That’s not a thread. That’s a ground down acme 3/8-12 thread. Meaning, you can’t screw anything there. So even if you could sandwich the rod between two nuts and oversized washers, you couldn’t, because the top portion is not threaded.
I appreciate your input Will. Helps me put those ideas to the test. I really wish an alternative approach would work, but this piece is just kind of weird.
This Jesse from RSK bearing . We produce most miniature bearings and flanges . If you need F608ZZ ,pls contact me Whatsapp: 0086-13736127301 or Email :rsk-bearing@foxmail.com.
RSK Company Website : www.rsk-bearing.com
You can always look up reviews online using keywords to pick the perfect one. The materials used in skateboard bearings are one of the primary things to consider when buying. Titanium bearings are a great option. They perform smoothly the way steel bearings do, and are lightweight and highly rust-resistant for longer-lasting performance.
