Trying to hold down and cut .004 inch aluminum parts, the 12" X 12" sheet lifts up and the cut quality is poor. I’m using 2 sided tape and an Amana bit made for aluminum, very bad burrs and chatter on the edge.
Any suggestions.
Any suggestions.
Is the sheeting actually 0.004" thick? (0.1mm?)
Suggest the following:
1 - Specify you bit details, RPM and feed rate/depth per pass
2 - Use masking tape and superglue instead of double sided tape, it is firmer.
3 - Use thin sheet wood above the aluminium plate to hold it down, cut through both.
Your main symptom is lifting/poor cut quality
The illness may be feed rate/bit specific or insufficient hold down.
