I have Arduino uno grbl 0.9j and easel 0.4.0. I have my own firmware settings. $10 keeps reverting to $10 = 115 from my setting of $10 = 3 when I go through “Z probe configuration”. My cnc system works in easel and probes with UGS. Hardware is Arduino 5v to plate and return to Arduino ground. It is an “other” in “edit your machine” window. In the dropdown “machine” > “edit your machine” > “configure z probe” > “confirm” > get green “attached” but cannot go further (z probing works in UGS so hardware good). In “carve” I cannot get past “Plug the lead into the carriage”. Suggestions for why no signal and is “carriage” a leftover from x-carve setup and how do I workaround?
After probing attempt, works with UGS.
• $132=100.000 (z max travel, mm)
• $131=600.000 (y max travel, mm)
• $130=450.000 (x max travel, mm)
• $122=10.000 (z accel, mm/sec^2)
• $121=10.000 (y accel, mm/sec^2)
• $120=10.000 (x accel, mm/sec^2)
• $112=1500.000 (z max rate, mm/min)
• $111=1500.000 (y max rate, mm/min)
• $110=1500.000 (x max rate, mm/min)
• $102=200.000 (z, step/mm)
• $101=200.000 (y, step/mm)
• $100=200.000 (x, step/mm)
• $27=5.000 (homing pull-off, mm)
• $26=250 (homing debounce, msec)
• $25=500.000 (homing seek, mm/min)
• $24=100.000 (homing feed, mm/min)
• $23=3 (homing dir invert mask:00000011)
• $22=1 (homing cycle, bool)
• $21=0 (hard limits, bool)
• $20=0 (soft limits, bool)
• $13=0 (report inches, bool)
• $12=0.002 (arc tolerance, mm)
• $11=0.010 (junction deviation, mm)
• $10=115 (status report mask:01110011)
• $6=0 (probe pin invert, bool)
• $5=0 (limit pins invert, bool)
• $4=0 (step enable invert, bool)
• $3=4 (dir port invert mask:00000100)
• $2=0 (step port invert mask:00000000)
• $1=25 (step idle delay, msec)
• $0=10 (step pulse, usec)
