Artcam - adding tapered ball nose bit to tool base
Hi. i ordered Tapered angle Ball Nose End Mill. I want to use it as a detail bit for reliefs.
This is a spec:
-Type: Tapered angle Ball Nose End Mill / Cone Cutters
-Flutes: 2 Flutes
-Tip Radius: 1.0mm
-Shank Diameter: 1/8"(3.175MM)((d1)
-Cutting Length:15mm (L1)
-Overall Length: 40mm(L)
-Single side angle B=2.24°(Approx.)
How do i add tapered ball nose bit to tool list in Artcam? What tool type should i use? Radiused Engraving or custom form tool?
link to the bit on amazon
Tapered Ball end mill
