I created a 3D project in Aspire 8. The project size is 23.75" inches (diameter), and will be carved onto a circular plaque (23.75" Diameter). There are a total of 4 toolpaths (roughing, final, final 2, v-carve). The material setup I used is dantrum bottom left corner; X 0/Y 0 position.
With that material setup, it should be straight forward… I set the circular plaque so that it touches the bottom 0 line, and the lefthand 0 line.
When I upload the aspire gcodes, the project piece is overlapping the lefthand 0 line by about a quarter inch. Also, the light translucent blue ‘job material’ shows in Easel that it is too far left, passing the 0 line.
I’m looking for some help, guys and gals!! thank you in advance
Basically, when I connect to my machine and auto-home the machine to the 0,0 position, and begin carving the material, it carves too far to the left… It is going into the (negative) space…
This is why i came back to the easel image, and seen that it appeared my project was too far to the left of 0…
It definitely could be that it just appears it’s too far to the left in the program due to the view Easel offers… I did play with it, and all angles appear to far to the left still. I attached a photo again of a closer angle
Well, I believe I’m using the vectric PP… I downloaded it from inventables “download” page. When it downloaded, all that happened was a document was uploaded to my homescreen on my desktopvectric-easel.pp (3.0 KB)
I am thinking that my computer is not loading easel PP properly. I just get a word document loaded onto my home screen. I am not sure why this is happening??
i downloaded the .3.10 driver … i believe i already had this done. along with the vectric PP. This is why i’m confused as to why it’s not working properly
