Read lots of posts but don’t see if anyone has cut one of these using F Engrave.
There is a huge post on this.
You could have posted there about using F-Engrave.
Sorry, I misunderstood your post. I read the post you are talking about. Didn’t see anything in there about anyone using F Engrave. You’re right it was a huge post. I guess I broke proper etiquette by asking in a new thread. Sorry
No problem they even talk about painting/finishing it too.
I may give it a go… after I’m done with time out
Several questions.
I know this dial is a huge file. It took F-Engrave 20 minutes to load the file, an hour and a half to calculate the vcarve. Now it’s rerouting loops, (whatever that means) and has been for 3 hours. I’ll let that thing reroute loops all night if that’s what it takes. Does seem right, time wise?
Is there any chance easel will run this g-code? I’ll get picsender or ugs if needed. (I’ve looked at picsender but not ugs, yet)
Do feed rates and DOC settings in picsender/ugs supercede the settings in F Engrave?
No one should reply unless certain I’m allowed out of corner. And for the record, while no one was looking, I was playing with my CNC. It’s in the corner I went to!
I don’t know about f-engrave, but V-carve pro loads it in a second and takes maybe 30 seconds computing toolpaths. What pc are you using?
I’m using a not-so-expensive laptop, though it is new and does have Windows 10 on it. I don’t recall the specs in ram or speed, but it’s been ample so far.
I have no doubt VCarve Desktop is worth every penny, and intend to buy as soon as possible, (like right after the real boss gives me the go-ahead)
You are correct, sir! You must be an inductee.
