Let me double check - I have my program set to imperial units by default, but the STL for the LP that gave 168" was converted from mm for sure.
OK! So the two DXF files seem to be in range, but they don’t have the necks attached and I’m getting huge numbers when I measure the STL files.
Going from the DXF files:
My Tele: 15.849 in
Your tele: 15.874 in
My LP: 17.238 in
Your LP: 17.304 in
I’d say that’s pretty damn accurate! As long as you’re somewhere near that for all your proportions, and your necks are made to scale (25.5" for the tele, 24.75" for the LP) then you’ll be fine. There’s actually a fair amount of wiggle room when it comes to scale length anyway since most guitars have a good amount of space to slide the bridge placement back or forward. Only the fretting needs to be accurate to the second decimal place really.
Long day
