Benchtop PSU from PC PSU
So I needed a bench supply for some arduino stuff I have been working on and so I decided to make something at least slightly elegant with my shapeoko 2.
It is all documented on my blog: http://livealittlemore.co.uk/2015/06/10/benchtop-power-supply-from-pc-power-supply/
I will just post some of the photos here and this is the video montage of the build: https://www.youtube.com/watch?v=Qb-fbTWZ688
NIce, but that fan that blows the hot air out of the power supply, needs somewhere to pull cooler air from. You might want to put some holes in the back (technically the bottom of the power supply, but the back of the enclosure as you are using it here) so it can breath, Depending on the load you put on it, it may not ever overheat, but that is how it was designed to work.
