Best and cleanest method for doing an image trace of a photo in easel?
Anyone have any suggestions for a cleaner cut when doing an image trace on Easel? Every photo I try to download comes out not so clean eve after I make adjustments to the threshold and smoothing settings. Not sure if Im just stuck with what I get because maybe Easel is not the right program to use, but any help would be appreciated.
Kevin
Got an example?
Neil,
Thats just one example, that is suppose to be 4 dogs
I meant an example image…I can see why you wouldn’t want the results from that, though.
Do you have the original image that you traced?
I don’t know that you’ll be able to do much with that image.
You could use Inkscape to get a greater range of depth, but I don’t know that it’d get you anything usable.
What would you do to finish a carved piece with an image like that?
Thanks Neil. I havent used any other type of program, this was just one example of an image, every photo I try to trace, it seems to have this same issue. Maybe ill try Inkscape.
Appreciate the help
