Better text boundries
Whenever you input text, in order to properly text relative to other objects, you have to merge the text with a 0 depth object. This isn’t a big deal but if you need to edit the text you have to undo all that. Can we just have a more typical text box?
You can run the Text Object through the Xploder application and gain regular editable objects. This can be much easier to work with…
{:0)
Brandon R. Parker
The problem with this is that if I want to edit a word, change a font, correct a spelling etc, and not lose proper alignment, I have to delete the word and start over.
Aligning text based on anything other than actual letter height and/or word actual word length makes a relatively simple process unneccesarily convoluted.
