I am new to X carve, how do you change the depth of cut and the bit size? Also heave trouble getting the carve to start on top left corner of the pattern. Any help will greatly appreciated.
Highlight the project. A drop down menu will appear. The heading has cut and shape. Under the cut tab you will see where you can use the slide bar to adjust the depth or you can type in the depth in the box.
As far as the x,y home position there was a very recent discussion on the forum under help centering x,y to carve correctly. Take a look at that
